Cold temps snapped something shifting into 4
Jerpaderp
Malmstrom AFB, Montana
Last week we had temps drop to around negative 50 and stay there all week. Because of the snow, I went to shift from 2wd to 4wd and when I did, I heard a snap, and the shift lever is now like a limp d***.. I can move it freely from 2 to 4lo without anything happening. I looked under the body and it looks like the linkage can't be reached from underneath. My question is how hard will it be to take it apart from above (inside) and what are the chances this isn't a cheap fix?
jeeptorino68
Oregon
you can get to it from underneath. the retainer probably broke off that keeps it attached to the lever on the transfer case.
a steel spacer, fender washer, and small hitch pin and i was all fixed up.
jeeptorino68
Oregon
also if you google broken shifter bushing for jeep liberty or something you will find some info on it for wranglers and i think one write up from this site. some good info, but mostly just crawl under and have a look
