Clunking from front suspension drivers side
Mangate
Mexico City
I have had this clunking from around 10-20,000km, but lately it seems to be getting worse. It sounds like a loose wheel or ball joint, but I have checked most likely culprits. The sway bar bushings are all good and all the nuts and bolts are tight. No perceptible play in the LBJ or wheel bearing.
I fitted OME springs and shocks all round with Al's A arms at 74,000km and the noise was the same after fitting. I changed the lower strut bushing in the LCA as the rubber looked overly squashed, no change in noise.
Any ideas?
Porkchop
Troy Mi
Rack and pinion bushings Front drive shaft Brake hardware Just some more things to check.
Mangate
Mexico City
After dismantling the front suspension, I found that the shock top nut was not fully tightened. When I fitted the OME springs and shocks I had to go to a mechanic with suitable spring compressors as mine aren't up to the job for Jeep springs.
I hit it with the impact wrench and it did tighten up a couple of turns. To fully tighten the nut I had to use a 6mm spanner on the end of the piston shaft then tighten the nut.
The strange thing is that I had the same noise before I changed to OME.
