offroadohio
Jeep 4.0 engine auto trans 8.25 rear axle ect
Parting my 1990 Cherokee. The body of this has 235,000 miles on it. I think the motor is a junkyard motor so it most likely has less but assume it has 235,000 on it.
4.0 and aw4 auto $100 complete minus alternator and starter, runs awesome, ****** works fine
Will split engine from ******. $75 for engine $50 for trans
Front driveshaft $25
29 spline 8.25 axle 3:55 gears. From a 01 Cherokee Welded carrier. 2 spare axle shafts. Just redid the breaks 3 rides ago ( drum brakes) $125
Rugged Ridge HD T-Link Steering System for xj,mj,tj Tie rod got bent, I straightened it and put some very thick 1.5" pipe over it to make sure it doest bend. $50
ac fan, trans cooler $5 each
Radiator from 94 $10
Located in ROSEVILLE OHIO 43777.
