check under the plastic on the rocker panel!
jeeptorino68
Oregon
i noticed the other day while washing that mud was coming out from under the plastic panel attached to the bottom of the rocker panel. this panel is here to hide the pinch seal that connects the outer rocker panel to the inner. but this plastic cover held a ton of mud/dirt...it was just waiting there to rust, i pulled off the plastic, not sure if i will put it back on because it will hold more dirt.
once i clean up the paint under there it will look fine.
just a warning.
