Chasing a ghost. Need experienced help- Oil Pressure
Mator1988
03 liberty sport 3.7l
Georgia
Oil light(red can with drop) comes on when I press the brake. I have replaced the pressure sensor 2 times. Changed the oil, filters new oil(synthetic blend), change back to covental oil plus did oil pressure check with manual gauge(flushed motor this time). A friend and mechanic told me to go with 20w50 so I did. Said oil pump was weak, that when I speed motor up the oil pump speeds up too. It has thrown multiple different codes. I change spark plugs it help some put new MAP helped a little. Now I'm using 89 instead of 87. I've researched. Results could be battery or pcm or vac leak. I've replaced crankcase breathers and pcv line. I'm ready to torch it but I love my jeep. Please old wise hands help me out. It's my first jeep( just empty every pocket ) first 4x4 and first vehicle with AC. It has a 3 inch lift before I bought it. Only had it almost 3 months
Welcome to the forum.
Sorry for all the questions but here we go..Did you use an after market or the better quality Mopar oil pressure sensor?
When you depress the brake pedal once & hold down, do you hear any hissing or a bit of an air leak?
Does the rpm drop at all when you depress the pedal ? What is the idle rpm in Drive, Jeep Hot when stopped?
What was the manual oil pressure reading in psi ? How many miles on your Jeep now?
What are the Problem Codes numbers?
Triple check the larger hose coming off the brake booster for any cracks or wear.
Hoping that the oil pressure will increase with a thicker oil may not be the best plan, that's old school, in a newer tight tolerance engine.
Unless it is very seriously burning oil, you should use the 5w-30, (especially if the pick up screen is restricted) it will flow & lubricate better & is what's specified by Jeep.
The pump could be weak depending on psi #s and dropping the pan and installing a new pump, cleaning screen, would be the best solution.
Looking forward to see the oil psi numbers at idle & revved up at 2000 rpm.
Mator1988
Georgia
When you depress the brake pedal once & hold, do you hear any hissing or a bit of an air leak? Does the rpm drop at all when you depress the pedal ?
$35 sensor. Didn't get the cheaper one.
Haven't noticed an air leak when braking
Idles round 700rpm with 10psi
3000rpm around 75 psi
148750 give or take a couple
P0158 p0158 p0838 p0151 p0300-p0305 coil packs codes had a few more. Charging system low. Checked with multi meter. B-12.8 off A-12.9 off. B-13.7 idle a- same. Pulled + off stayed running
Mator1988
Georgia
Unless it is seriously burning oil you should use the 5w-30, it will flow & lubricate better & is what's specified by Jeep.
The pump could be weak, however the pick up screen could also be restricted with debris.
Was using 5w30 in reg oil and synthetic blend. Had it put on computer at shop. Oil pressure was all over from 0.05-101.3 and in between. said jeep was 180 out of time. Cant believe that or it wouldn't run and if it did it wouldn't have be so smooth. I could see it jump a couple teeth had new oil pump rod bearings done before I got plus heads were sent off
$35 sensor?- Did you install a Mopar oil pressure sensor?
Mator1988
Georgia
Do you think I need to order it from Chrysler? I've checked the harness didn't see anything. not shorting out or grounding out that I could see or find
Yes absolutely. Only the Mopar can be trusted & will be calibrated correctly for the KJ's Pcm.
BTW the Mopar sensor will only turn on the oil light if it was to drop below 4 psi.
For now, I'd say get the Mopaar sensor installed and see if the light still comes on.
The manual psi test dropping that low even after the new oil pump has been installed, has me quite concerned.
Let me see if I can find the Mopar pressure sensor online stand by..
Mator1988
Georgia
I read at 650 rpm it shouldn't be lower than 4psi. Friend told me to hook up manual gauge and go for a good drive and watch the gauge when it's in operation. do you agree that I need to try that
Mator1988
Georgia
Ok I feel like that would be alot to drill extra hole in block. I've replaced the oil pressure switch located right above the oil filter. What I saw is either I don't have a 3.7l motor. Or the jeep body is listed as 03 and motor out of 04
Yes try using the correct MOPAR oil sensor
Have installed a few that people bought from their local rip off store only to have them come back with same issue
Personally I would NEVER run oil 20W50 oil when it calls for 5W30
I have an 04 I bought new with over 232,000 miles on it and 5W30 still does great in it ( well use 5W30 full syn in all 3 of mine)
Guys used to do that back years ago if selling a junker and trying to get one over on a possible new owner
also running 89 instead of 87 is just costing you more money, not helping
03 with a 04 motor ????????
First it won't work without someone doing a ton of work to the 04 motor to make it work in an 03
Mator1988
Georgia
Cold start she ilde at 1000 rpm whit no sound. After about 4 minutes she warmed up and in best way to say it half whine half wirl sound and drops to 700 idle
Mator1988
Georgia
No air leak on the lines I was referred to to check. Adjusted idle screw. I thank you gentlemen for the knowledge yall have passed on to me. I will order switch from dealer
