Can you run UV dye in the coolant all the time?
GitEmSteveDave
Howell
I'm just wondering if it's safe to add some dye and when I pop the hood at night every once in awhile check to see if anything lights up, or if it should only be used when you are chasing a leak.
Unless you notice the recovery tank a bit low (a sign of a leak) No need to add a dye.
Do you have a leak?
GitEmSteveDave
Howell
dried coolant is also kinda fluorescent as well so you don't really need to add dye into it.
It isn't, sadly, which is why I asked. I have a pocket UV light I always carry on me and I use it when I pop my hood, but even when I had the water pump leak, it was near impossible to see when it dried.
really? i have the opposite experience.
I personally would try pressurizing the system before I added dye.
GitEmSteveDave
Howell
I'm gonna walk that comment back a little because I realized that I was basing it on whatever coolant the shop that replaced the engine used. I just watched the Jeep Dealer put HOAT in, so maybe it will be more vibrant under my pocket blacklight.
