Both Rear Window Roll up but not down
Clampet
South Dakota
2004 Liberty,
Front windows work both direction.
Rear windows only work in up direction. If I reverse pole they work in down direction.
Both Master Front and Rear window switch behave the same works in one direction.
Tried 3 different Master Switches. All behave the same.
Would it be the Window Relay??
Motors are good, window regulators are good.
Its a 2004, with Orange wiring to master and rear switch. I dont have a diagram for those color code wires.
Any thoughts.
Thanks in advance
Here is the color /wiring schematic rear windows from my 2004 Factory manual.
daves06lrenegade
Massillon, Ohio
For the windows to operate in EITHER up or down mode you MUST have (+12 volts) and a ground return... Because they work in one direction but not the other we know both +12v and ground is present going to the switches (on the back doors) the back door switches are bad...
