Best 2" lift kit
Discussion in 'Introductions' started by Nutty, May 26, 2019.
  1. Nutty
    Nutty New Member
    May 26, 2019
    Looking to put larger tires on my 09 KJ. Not really a trail guy. Mostly for cosmetic purposes and a little more clearance in deeper snow. Any recommendations on a budget friendly lift.
  2. Nutty
    Nutty New Member
    May 26, 2019
    2" to 2.5"
  3. Nutty
    Nutty New Member
    May 26, 2019
    Correction- KK
  4. tommudd
    tommudd Moderator Staff Member Moderator
    17,849
    449
    Does not matter if you are or are not a trail guy, same lift applies
    OME springs and then a full set of OME or Bilstein shocks for a 2.5 inch lift
    If you would like the numbers we can give those to you.
    But that is it anymore , OME makes a great product, have installed over 50 Liberty lifts using OME and have personally ran them on mine at one point
    About 800 or so for springs, shocks, of course would need bumpstops etc.
    budget and lift do not go together unless you just want to lift it and let it sit in the driveway
  5. Nutty
    Nutty New Member
    May 26, 2019
    Well within what I was looking to spend.. Thanks for the recommendation.
  6. tommudd
    17,849
    449
    OME 927 front springs with 90009 front shocks
    rear OME 731 springs and N132L rear shocks
    Teraflex front bumpstops
    can use 2 hockey pucks per side in the rear bolted down to the lower spring perch for rear bumpstops
    Now on the KKs due to the different style of rear suspension it will pull the rear of the body over some
    due to the trac bar
    Check Jeepinbyal for everything
    Nutty likes this.
  7. Nutty
    Nutty New Member
    May 26, 2019
    Thanks for the numbers. Lookin forward to starting this little project with my daughter as this will be her vehicle in a year.
