best 2.5 spacer lift
IVIike13
who makes the best 2.5inch spacer lift. i have a 2006 liberty and im just starting out to do things to my jeep it will probably never see the off road or in the near future it wont
Eddo
USA
If you don't have the CRD, then Rusty's is probably your best bet.
If you have the CRD, then the Daystar is your best bet.
KJ04
Grafton, Ohio
Eddo, he asked about a spacer lift, not a coil lift.
By all means, disregard Rusty's spacer lift!
The RRO 2.125" Combo is a very dependable spacer lift, just add a 3/8" Clevis lift to the front and you're about 2.75" to level the front out to match the rear 2.5". A new set of Rancho H.D. struts would also be a good idea while you have it all apart.
The Daystar 2.5" front is an inside the coil spacer and will really stiffen the front end up to the point you won't like it.
