Hi all,
Went to start my 04 3.7L and noticed the check engine light was on. Popped the hood and noticed the electric cooling fan wasn't turning. Can't look into much at the moment cuz damn faulty hood lifts nearly fell and killed me.
These fans supposed to go bad after a given time? I suppose I will check the fuse when I get new lifts first. Probably a bad motor or relay? I guess I could check the motor by unplugging the fan connector and hooking some jumper cables to each terminal of the battery and the other sides to the 2 pins on the connector for the fan....
Let me know if I shuold check anything else or your thoughts
