Anyone try 215x85x16 tires?
t_bois
colorado springs,co
While these tire are not wider then the stock, they are only 10 mm more narrow and 1.5" taller. I don't have a lift and have found a good deal on some aggressive snows. Where are the trouble areas that I'll have problems with rubbing?
icarl
Peace Country
I don't know if anyone has this tire size on a liberty but according to the chart below it likely fits in the minor rubbing w/ lift club
16" tire height rubbing
235/65 152.8 no rubbing w/o lift
215/75 161.3 no rubbing w/o lift
235/70 166.9 no rubbing w/o lift
225/75 168.8 no rubbing w/o lift
245/70 171.5 minor rubbing w/o lift
235/75 176.3 minor rubbing w/o lift
255/70 178.5 minor rubbing w/ lift
245/75 183.8 minor rubbing w/ lift
215/85 185.3 minor rubbing w/ lift ?? ***
265/70 185.5 minor rubbing w/ lift
265/75 198.8 moderate rubbing w/lift
235/85 199.8 moderate rubbing w/lift
275/70 206.3 moderate rubbing w/lift
icarl
Peace Country
This tire size sound like an awesome size for snow though. And the nokian hak.. LT makes this size. It makes me reconsider my 235/85 size I am thinking of getting for a winter tire. The narrower the better for cutting through snow. I wonder if it will fit a prelowered liberty. hmm... probably not because my 225/75's already rub slightly when hard turning and there is little space between the tire and the front wheel well already.
Jeger
OH, Dayton
Something is not right if 225/75-16's are rubbing...that was a stock size for all CRDs in the states and I have never heard of any issues with them. Maybe you have some serious spring saggage going on?
I had made up my mind about 237-75's but the 215/85's are tempting me again. I would be careful about how aggressive a tire you go with in the 215's. I think the ones in that thread were pretty tame and rather small in actual diameter for that size. Others are bigger and would probly rub a bit.
icarl
Peace Country
It might be sagging a little in the front but not sure because I still seem higher than most lowered libertys looking from the rear. However, I think the generals have such an agressive tread that this could be part of the problem as well. It has rubbed against the fog light access door on the left side and also my fender cover got pulled off once on the left side (possibly due to rubbing?). I'm itchin' for a lift kit now and hopefully that will solve those issues.
Jeger
OH, Dayton
That is a good point about the grabbers...they are wider than other tires of the same size. Still havnt heard of this before though. Any excuse for a lift is a good one though!
t_bois
colorado springs,co
Jeger,
Have you made up your mind on the 215 tires? I will be talking to Big-O this week on how we can check for rubbing and how they want to work this if they do.
Jeger
OH, Dayton
Jeger,
NO...right now it looks like its going to come down to what I can afford.....regardless of size
let me know what you find out at big O
Staff online
