any way to make my electric fan work better?
hadtomer
Israel
Hey guys!
I am on a mission....i want to modify my cooling system to the max.
I have a 3 row rad. a mishimoto thermostat and a severe duty fan clutch.
and sure- i am happy with it.
living in a warm climate- my kj already had the so called heavy duty cooling package- but there is one more thing to do (and it's a direct result of me being bored and having too much free time) - i want to make the electric fan work better.
When i say better i mean 2 things: faster (or should i say more efficient) - and i want it to start working sooner.
on my previous rig i simply mounted a HUGE spal fan in front of the rad- so no problems there....i could flip the switch and get instant cooling - but there is no room in the kj for that - plus why mount an extra electric fan when i have an electric fan....
so any ideas? maybe change the control unit?
libordemise
CA
Wow.. Do you have a part number for that fan clutch? I'm thinking you have a great idea about maximizing cooling!
Sent from my LG-K210 using Tapatalk
you can always hard wire your electric fan.
since you have an 06, you would have the 2 speed fan so hard wire it so the high speed comes on.
The other thing is even though you have the clutch fan, is it a severe duty one?
I know NAPA had a HD and a SD clutch fan. The SD clutch engages at a lower temperature than the HD I think.
other than that, I think you could add those misters.
hadtomer
Israel
Track order
Hayden Fan Clutch Severe-Duty Thermal Jeep Comm...
Item ID: 191404162599
Quantity: 1
Estimated delivery: Mon. May. 8 - Mon. May. 15
Paid: $89.77 with PayPal
libordemise
CA
Does it make a pretty noticeable difference in temp? I feel like mine blows cold enough air without even a.c. because I've got hoat now with a brand new mopar rad, I probly could disconnect my a.c. or bypass it if that clutch works well enough!?!
Aztimer2
Glendale,AZ
Hey guys!
I have an 02 Liberty Ltd 3.7, will that model take a 3 row Radiator ? I'm in Arizona heat and I see my temp gauge go past the mid range a little while in traffic.
Sent from my iPhone using Tapatalk Pro
mrlavalamp
Sin City
The Hayden 2905 is the Severe duty. My parts store found it listed under the CRD liberty.
Hayden 2736 is the Heavy Duty, and was listed as the only option for the v6 3.7.
I believe the difference is that the 2905 severe duty clutch activates (tightens up?) at a lower temp vs. the 2736.
As far as actual effect on temperatures one vs. the other, I cannot say. I went straight to severe duty when I installed HD cooling.
Climbing up to Eisenhower tunnel,at 11,000+ feet,with a 6400 lbs KJ with a stock 3.7 and stock cooling system(non-HD cooling,just electric fan) with outside temps in the 70's I barely touched 224 degrees and that is 8+ miles at 4500+rpm's.
Is 224 worrisome?
Not really since the electric cooling fan does not come on until 219 degrees.The needle for the temp gauge will move to 3/4 at 229 degrees.I have my Edge CTS monitor warning set to 225 degrees and It's never set the alarm off in years.
For those with HD cooling the OE clutch does not "lock" till 230 degrees.
libordemise
CA
[emoji50]
Aztimer2
Glendale,AZ
What is the temp when the gauge is straight up
Sent from my iPad using Tapatalk Pro
