Yo have to go to the battery. A 120 watt amp connected to the radio harness is a fire waiting to happen. Vehicle fires are no laughing matter. I've been in two vehicles that have caught fire because someone thought they were an expert.
Wires going through door jams.... fire waiting to happen.
Yeah, right, 120Watts, which is only 10 amps at most for a GOOD Mosfet powered amp. Cheap ones with 7AMP fuses are LESS. Seeing as it has been this way for just over FIVE months now? I will be desperately WAITING for your huge fire, that won't happen. Yeah, that and a weak battery will cause my engine to run crappy, Phhh...
I had a 400 Watt amp hooked up to my power seat lead in my Avenger, huh, no fire, what did I do wrong there? What a shame, I was hoping for a fire...
I do not THINK I am an expert, because I AM an expert. I know what guage wire can handle what current. The HU only uses so much, plus the AMP? Yeah, if you suck at math you may be in trouble... For some reason, again, I just seem to to everything right...
Fact is, not one vehicle I have ever owned has caught fire due to wiring. The only time I had a fire? My interior lights went out, and some dope used a lighter to try see under the dash and he caught the insulation on fire, only so briefly. This was a 1984 Pontiac Phoenix 5sp, NOT the hatch-back.
I could list every car, starting with a 1969 BMW 2002, that have ALWAYS had loud stereos, with no fires, and my wiring technique. Do I take offense? Why not, you question what people do, when you don't know any better. I will continue to wire the way I wire, based on MATH, maybe something you need to try... Maybe you ALL need to take a course on electricity, because apparently, some people don't know spit about it.
