Airbox/Air Filter question
jimbrown
New York
I recently replaced the air filter on my vehicle. I have few questions about the airbox/filter.
Inside the airbox is a smaller rectangular cavity.
ImageShack® - Online Photo and Video Hosting
The cavity houses a small orange (once orange) rectangle foam. It is pretty fried. Not sure what it is. I assume its a filter for air that is supplied to the cabin, as there is a hose that connects to the hole in the cavity which houses the foamy thing. If it is a filter I assume I should replace it and that its a standard fit that most Auto chains would carry?
Luke
Interloper
Bancroft, Canada
You mean Sponge Bob? :D
That is the filter for your crank case ventilation .. you can get one from the dealer but it's not necessary. In fact the one I got from DC did not even fit (had to trim it).
Either clean it as best you can or just replace it with a piece of similar (airflow) sponge.
osufans
Central Ohio
Just thinking off the top of my head, I know my aquarium filter uses some fairly porous foam. Not sure how much the dealer wants for that piece, but you could probably grab a piece of foam for an aquarium filter and trim to fit as well.
Luke
Interloper
Bancroft, Canada
That is what the "new" ones from DC look like ... more like a scouring pad than the original foam.
Better late than never..
A new inexpensive Mr Sponge Bob is available. Mopar part #05066076AA
Poor little guy had shrank & was crumbling! :)
duderz7
Weiser, ID
I picked up a foam air filter for a lawn mower and cut to fit, it was dirt cheap. Good to know a factory replacement is available.
