Air con regas
Plentybootspace
Scotland
Hi all I have a 2002 kj 2.4 petrol and my air con is completely empty of refrigerant. The question is can I simply fill the system or do I need to put compressor oil in it. Any info is welcome
brokendad
Edmond, Oklahoma
Here in the States almost all of the DIY air conditioning refills have compressor oil in them. I would think that compressor oil should be used every time you have to recharge the air conditioner.
If its empty then more than likely I would assume you have a leak in the system. if so then you need to get it repaired and then go through the whole system, it will need to be drawn down / checked and then filled if possible
