I have a 03 Liberty that needs to have its air compressor replaced because the clutch is making a lot of noise and there is black goo all over the place.
There is also a noise that sounds like water going through pipes with gargling like noises (similar to like sipping a straw from a cup that is almost empty).
Took it to the Jeep dealership and they said that there was nothing internally damaged with the compressor and that it was just the clutch.
They recommended just to replace the air compressor with a new OEM part. Will that resolve the gargling like water noises that are being made also?
I have read on this and other forums that for the warranty to be covered on a new air compressor, that the orifice and dryer/receiver need to be replaced too.
The technician said that was not necessary because the compressor was not damaged internally.
Will I have a warranty problem later on down the road if something happens again. The technician says no, but how can I be certain?
