AC pulley??
jnaut
Seattle
It seems to me that here's the process I'd go through if I wanted to save a few bucks on the labor:
1. Go to professional, have them recover all r134a.
2. Take car home, replace parts/compressors as necessary.
3. Return to professional, have them recharge system after pulling necessary vacuums etc.
Here's the deal with those Autozone based r134a charging systems. And a certified A/C repair shop confirmed this with me one afternoon.
It's a closed system. If your system isn't leaking, you shouldn't have to recharge it. Ever. Once you find the need to recharge it, your system is leaking. Yes, it can be a very slow leak. However, what that means is you are leaking 134a into the air. No different than you simply releasing it into the air yourself. The only difference is it's happening over months instead of over 15 seconds.
Replace your own compressors to save some $$$ on labor and shop costs. But rely on a professional to do the recover and recharge. It's worth it and it'll be done correctly.
kb0nly
when i put on the new compressor, it is ok to drive the kj to a place to recharge the system as long as i leave the ac off right?
in other words, im not gonna burn up the new compressor by driving it am i?
Nope, and it wouldn't kick in the clutch anyway, the low pressure cutoff switch would keep the compressor from cycling.
Uncle Krusty
San Tan Valley, AZ
True, but I would also NOT hook the clutch wire up - just to make sure. Tell the shop you didn't, just so they don't start replacing the preasure switch and such...
UK
flair1111
usa
just for a note to the thread. i had this done about 2-3 months ago or maybe more, it is working now. here is what i did for anyone who might read this and have questions...
1...$299...bought remanded compressor (filling with 8oz of oil that came with it and sitting it nose down over night as per instructions)
2...$49... bought new accumulator
3...$50 IIRC... bought new (1) aluminum tubing/hose ...cant remember what its called...parts guy will tell you about it anyway.
4...FREE... i took out the old compressor, accumulator and aluminum tube/hose
5...FREE... replaced all parts with new parts
6...$109...with the ac OFF and fan OFF (just to be safe) i went to jeep dealership and let them pull a vacuum, and replace with correct amount of oil and freon.
done deal
this was the cheapest and safest way i found to do this swap for the ac system.
EDIT: these are prices as of early 2009.
EDIT again: even if your clutch is all thats messed up, if your compressor has a fair amount of miles on it, ild suggest to STILL replace the whole compressor just for cost sake. Youll see what i mean when you start getting quotes and figuring wear into the equation. Your call though.
jnaut
Seattle
1...$299...bought remanded compressor (filling with 8oz of oil that came with it and sitting it nose down over night)
2...$49... bought new accumulaotor
Thanks for the update, Flair. Good to know about what the parts costs are on these things.
