AC drain hose location
jaytango
orlando
I spent all day trying to find the darned ac drain hose. Still no luck. I looked for the nipple mentioned in the previous thread but no luck. It seems so easy to find in the kj but no luck on the kk. I'm getting a musty smell when I turn on the ac and there is NO dripping whatsoever under the car, even after sitting for 10 minutes with the ac running.
jaytango
orlando
Finally found it!
I finally found it, thanks to this thread: https://www.nitroforumz.com/threads/a-c-leaking-water-under-the-carpet.41454/ Here is a pic of the drain: https://i.imgur.com/NqFNb5V.jpg And here is a video of where I cut out the head shield to find it: https://www.youtube.com/watch?v=3h3GRagAsdI Worst location I've ever seen. Underneath the car, in the middle, right in between the driver and passenger floor pans, right above the transmission, just above the shift linkage, hidden behind a foil/insulation heat shield. The water must drip onto this heat shield pad and flow down to wherever gravity decides to take it.
