Abs/esp/traction lights came on
ChiefRudy
Pittston, Pa
Having a good day here. Wife's home from work and tries to go out and her jeep keeps stalling(damn compass)... So I tell her to go back and take my KJ. She drives around the block and the abs/esp/traction lights came on.
So I'm figuring its a faulty abs sensor. As recently I been noticing the front driver abs has been act activating when I'm breaking and taking a tight turn regardless of which way on turning. (Example, a quick pull into a parking stall)
So am I correct on my assumption? Anything else I should look at?
Thanks guys
Gyro
Nova Scotia
I had the same lights on my 06 renny a while ago,I did a code check and got a low system voltage code.
Replaced battery(warranty) and all has been good since.
Check your battery.
Gyro
ChiefRudy
Pittston, Pa
I'll have to check the codes. I do have a scan gauge on my jeep so I'll check the voltage output with that and a multimeter . I did put a new battery in almost a year ago. Thanks for the tip but knowing my luck it's not gonna be that easy.
