Hi everyone, new to the board as you can tell...
Replacing a bad hub, front left, 2006 3.7L 4wd. Can't find where the abs cable plugs into in the engine compartment. Traced the wire up to where it seems to disappear into a bunch of taped together wires, right under the four big color coded plugs by the brake fluid reservoir. Gonna go and cut away as much tape as I can, but it's hard as heck to reach under everything! Thoughts or ideas?
Thanks,
-BfloRandy
Additional issue... Hub won't separate from the spline. If I can get them apart, I'll just disconnect the sensor at the hub and keep using the old one! Cut away tape, and only find where the wires disappear into a bundle.
Thanks,
-BfloRandy
