5 speed manual trans
Ok when I got my Liberty recently I didn’t have a way to get it up to 5th gear on a test drive. I just took it for a quick run up to highway speed and it wouldn’t go into 5th. There’s no grinding noise. I’m thinking I’ll have to drop the transmission and replace 5th.
Billwill
White River, South Africa
Yeah I have the 5 speed manual gearbox..no problems at all.
Is the oil level correct and has the correct gearbox oil?
I presume you have downloaded the relevant manuals for your Jeep here:
If you are looking to replace the clutch at the same time read up on the process..the Flywheel has a curve in it which must NOT be machined down!
I haven’t had a chance to do fluid change yet.
Billwill
Make sure you use the correct specification gearbox oil...my local Jeep Dealers tried to persuade me that ATF+4 was the correct oil for the 5 speed manual gearbox!!!Wrong!!
ATF+4 is for the Transfer case!
The link to the Jeep KJ Manuals I sent you has the list of the correct fluids for your year KJ...including HOAT anti-freeze fluid for the cooling system.
