45RFE for a 42RLE
Her Jeep
Fuquay Varina,NC
Is it possible to switch out the 42rle for a 45rfe in a 2011 kk 4wd. I would prefer the extra gears for fuel saving sake.
jeeptorino68
Oregon
those transmissions have the same gear options. i think you mean the 545RFE? if you do it is the same as a 45RFE it just has a different program that adds another overdrive.
How much money you have? Better off taking the couple thousand $$$'s needed to do the swap(mostly custom computer programming) and put it towards alot of gas.
The 42RLE and 45RFE/545RFE are 2 competely different trans.
04Liberty
MD
Totally different gear spacing between those 2 transmissions. tjkj is dead on, you would have to spend a bunch of money to get it to work correctly. The 42RLE actually has a steeper OD ratio (.69:1) versus the 45RFE's (.75:1). Even when programmed out to the 545, the OD ratio is still only .67:1, marginally better than the 42RLE and not worth the effort.
jeeptorino68
Oregon
is it worth it to get your 45RFE programmed to a 545RFE in the liberty with a 3.7? the 3.7 is pretty marginal...so less RPM on the highway wouldnt be much better...
04Liberty
MD
It would only be worth trying to do (dunno if you can even do it with a KJ) if you went to say 4.10's and wanted the extra OD for highway driving.
