Jeep Liberty 2008 Cooling system code and stalling/ overheating
LimC
Hi guys I am lost with this 2008 jeep liberty 3.7 Limited.
It has a constant engine light on saying the cooling system is faulty even thought it has no signs of bad water pump and has plenty of coolant. I will drive for about 25 mins and the jeep will start to gradually overheat then once it sits at the highest the temp will go on the guage for about 2 mins then it drops all the way back down to cool and pops on the throttle body light and the service 4x4 light I’m not sure what this issue could be especially cause
none of these lights have anything to do with each other? It also will start just fine at a cold start then after about 20 mins and going through all the previously mentioned problems it has a really hard time starting it takes a couple time turning the ignition to get it to start or won’t start. Then if it’s parked for about an hour it will ask reset again?
What’s the code you’re getting with the check engine light?
Pitneykk
Have the TIPM fuse box checked in the engine compartment . The are known to go bad
