2006 Liberty Limited
micahstufflebeam
Monterey
Hey there, new guy posting..i have a 2006 liberty limited with the 17" wheel... whats the biggest tire i can fit without rubbing? I searched and only found 16"
Something in the 29 inch tall range
Good way to do it, find a tire you like on Tire Rack then look at the specs under 17 inch,find a tire that is in the 29-29.5 range and there ya go
235-65-17 is one example of a 17 inch size that is 29.2 inches tall
micahstufflebeam
Monterey
Thats what i have on there right now. Is that the biggest i can go?
You could go 245/65/17. Might have minor but fairly harmless rubbing depending on how much sag you have.
street_jeepKJ
Richmond, VA
I have a 05 limited liberty with 245-65-17 on the front with the stock 17 chrome clad wheels and have no issues at all, no rubbing even when I do tight u-turns. when the wheel turns it just barely passes so any bigger will most likely rub unless you plan on doing a lift
