ZERODSM
Following the how to on the courtesy lights was pretty simple but I only spent all in all 10 minutes installing them....
Popped hood and disconnected the negative battery cable
Driver Side
Pulled off the bottom black plastic and pryed the drivers side dash piece down....Seen the wire, un hooked the tape, connected the light, and bolted it up and place...I wasnt sure if there was going to be any hardware on the jeep to bolt it into place seeing as how the light didnt come with any hardware... Bolted everything back up voila done....3 7mm Bolts is all that was....
Passenger side
Pulled off bottom black plastic, Emptied out glove compartment, and felt behind that C channel....Found the wire...I just gave a little tug on the wire, I figured I would either Beak the tape or snap off the connector...Tape Broke thankfully....Put the light up lined everything back up tightened the 3 7mm bolts
Reconnect negative terminal...Done....
Feet lighting is so much nicer to have
First of many more to come....I still want to change my interior to black but for the moment til I find a Clean replacement I can only do small things at a time....
Next mod is Install EVIC system....
Anyone have the proper Model number for an 04,05, or 06 Evic system....WITHOUT The tire psi reading?
Also changed out the plugs today and noticed much smoother idleing and less hesitation....46xxx on the original plugs I bet the gap was all the was up to .052-.060
Driver Side
Passenger side
