honu
Some time back, maybe a couple or three years ago, I installed a set of Dodge Magnum R/T, 18" wheels and 225/60-18 tires on my 2002, two wheel drive, Liberty Limited. I wanted a custom wheel, I had these in my garage and, besides, they're forged and a lot stronger than most "affordable", aftermarket wheels.
I posted up a photo to show off the new look and a member here brought up an excellent point I hadn't been aware of. He brought to my attention to the fact that the Dodge bolt pattern was 115 on 5 vs. the Jeep's 114.3 on 5. He was concerned that there'd be problems with the wheels not mounting properly and possibly shifting, causing the wheels or studs to crack or even fracture. Unfortunately, my fiscal situation at the time, precluded me from buying new wheels and tires, so I was stuck with these.
Anyway, today I had to replace the tires and while doing so, inspected the wheels, lugs, rotors and brake drums. The manager of the tire shop checked them also. We found there was no abnormal wear or cracking of the wheel's mounting pad or around the lugs bolt holes.
He pointed out that the wheels are "hub centric" and don't use the lugs to center the wheel, so there'd be no chance of the wheels shifting on the rotor or drum.
Just thought I'd pass this information along...
Here's a photo of my Jeep with the new tires, I went up to 255/55-18's in order to correct the speedometer... they look and fill the wheel well better than the previous tires did.
This Liberty is driven almost exclusively on the street, by my daughter... the only "off-road" it's seen is an occasional, 15 MPH, fire road excursion, when the family's out "camping" in the motorhome.
Obviously, I'm no expert, so I'd be very hesitant to recommend use of the wheels for vehicles bouncin' around, out in the boonies...
