06 KJ Reverse Light Switch
TayJeep
Indiana
So my daughters 2006 KJ has all the lights working Except the reverse lights. Based on my research this would more than likely be the switch mounted on the driver side of the auto ******. My issue is I can't identify what is what since there is more than one and all seam difficult to get to. Can anyone tell me what color the wires are or even supply a picture?
Thanks!
It is called a TRS transmission range sensor I believe on the auto, 10 pin see image found now below.
50006[/ATTACH]"]
50008[/ATTACH]"]
Troy or Tom should be able to give a better description & testing. There must be a fuse as well for it. Do you have your owners manual is there a fuse listing for backup bulbs anywhere?
Wonder if it could be a ground problem though the the rear lighting wire harness / right D-pillar behind the quarter trim panel ?
TayJeep
Indiana
Thanks for the diagram. I don't have an owners manual but I did look up the fuse and it looks like the brake lights are included so since they work along with the tail light I would assume it is not the fuse or ground. The reverse switch looks like a pain to get to but that may be my only solution.
maybe check the bulbs and the wiring at that end before getting into checking the wiring at the bell housing.
