05 jeep liberty front bumper
russu1980
i have a side bulb that is out on the front bumper there are no screws there how do you take it out and replace it and also what kind of bulb is it????
fdems
Orange County, New York
Refer to your Owners manual, there should be a complete listing of replacement parts available. If not be more precise in which bulb (ie. turn signal ,parking light.) it is and i'll look it up for you.
russu1980
bulb 168 its the side square look not the rectangle in the front thanks alot
fdems
It's called the front side marker light and you could access it by carefully puling off the grill piece and try to get to it behind the turn signal lamp.( you may have to remove the turn signal assembly for access. ) Take a look and play follow the wire you should be able to figure it out. Good Luck..
