02 V6 iac problems and rough idle
Nicodemus Arceneaux
thinking IAC was bad, replacing that, but really rough idle. replaced plugs.. unsure about ign coils. two plugs smelled of gas/wet. maybe a valve cover gasket leak i think. plus a intermittent tap from valve cover area. please help its my only vehicle
How many miles on the Jeep? Spark plugs, did you use NGK ZFR6F-11G
Ignition coils could be an issue, do you have an engine light on or codes present?
Which plugs were wet or what was cylinder locations?
Tapping noise, may have to remove valve covers for inspection & see if anything is askew.
Is your oil clean from dipstick? Any smoke out tail pipe at start up?
Nicodemus Arceneaux
p0505 IAC motor circuits
p0500 VSS not detected(new sensor and harness)
p0353
Ignition Coil # 3 Primary Circuit
p0352
Ignition Coil # 2 Primary Circuit
p0351
Ignition Coil # 1 Primary Circuit
p0141
1/2 O2 Sensor Heater Failure
p0161
2/2 O2 Sensor Heater Failure
found those using the ignition key cycle trick
oil is as expected,
new plugs ngk zfr6f-11g
exhaust is clean
odometer is at 227878
Geez, That is a lot of codes going on.
IAC get a Mopar one.
VSS look above for proper grounding & any connection issues.
Get 6 new ignition coils installed. Mopar are best although I had good success with Standard Brand.
codes 0141 & 0161 are oxygen sensors, use only NGK or NTK 02 sensors for the Jeep.
You might be able to swap The 30 Amp ASD Relay or get a new one, see image location from under hood distribution panel.
It is # 6 for the ASD on my 04. You will see it labelled on your's once you open the cover.
Nicodemus Arceneaux
I’m suspicious tho because all these codes appeared literally overnight.
