Me and a friend were working on his liberty. We changed a wheel hub, and I took the front calipers off to spray some permatex disc brake quiet on it. The drivers side caliper was replaced a few weeks ago with a new one, and the pads and rotors are mostly new for the most part.
After we put everything together, we noticed that there was almost no brake pressure, even after stomping on it for a while. It did get better with many hard brakes, adjustment, and even bleeding each wheel around 5-10times. We dont notice any fluid loss anywhere. The pedal builds up pressure when the car is off, but falls when started. Its at an acceptable level now, you can actually stomp on the brakes and lock up the wheels, but its still spongy, compared to before.
I was baffled. I couldnt think of anything either then maybe a pinched brake line, or leak, but I didnt find anything. I'm thinking to replace the master cylinder tommorow. Its just odd that it happened suddenly.
