From; Creative Steel
02-07 JEEP LIBERTY (KJ) POLYURETHANE FRONT DIFFERENTIAL BUSHINGS $129.95
Do you feel or hear a “clunk” when accelerating/decelerating? If so then your front differential bushings are a likely cause. The rubber material that the factory used for these bushings is very soft with considerable air space in the bushings, and these bushings are under tremendous strain during vehicle acceleration/deceleration. These three points lead to the early demise of the factory bushings.
Our polyurethane front differential bushings are the perfect replacement for your old cracked or missing rubber OEM bushings. Our replacement bushings are made using polyurethane that is stronger than the OEM rubber and they are 100% filled (no air space) which minimizes deflection between the inner aluminum tube and the outer housing.
