Offsets, Backspace, and other wheel info
Bennett
Active Member
Green Bay
Backspace to Offset Conversion Chart
The table below is a quick reference for finding offset- pick the rim width and follow the row over to the backspace of your wheel.
Bolt pattern or lug pattern or bolt circle is determined by the number of bolt holes and the bolt circle diameter.
Hub Diameter or center bore is the hole at the center of the wheel.
Rear spacing or back spacing is the distance from the backside of the wheel mounting pad to the outside of the rim flange.
Offset: The distance from the centerline of the wheel to the mounting surface of the wheel.
Negative offset: When the back of the bolt pad is closer to the inside of the wheel; when mounting surface is inboard of the rim centerline.
Positive offset: When the back of the bolt pad is closer to the street side of the wheel; when the mounting surface is outboard of the rim centerline.
Bead-Loc A device which captures the tire bead between it's flanges, usually secured by bolts to keep tire bead from dismounting. Usually used in dirt circle track or off road applications where low tire pressures are used and hitting ruts or other vehicles are common. Left: An example of a Bead-Loc wheel
Info on Stock Wheels:
Bolt Pattern: 5x4.5" or 5-114mm
Backspace: 5.5" (might be a hair larger than this actually)
Offset is 41mm ( I know the chart says 38, but I found 41 from a tire vendor that said the factory wheels are 41 )
Wheel size is 16 x 7
Stock Tire Size ranges, but 235/70R16 is most common.
If anything seems wrong please correct me.
Bennett
kolesy
Goldsboro, NC
Hey can some one explain that vhart to me up there for the backspacing? I dont really understand what all the numbers mean. I know my tire width and i have a stock '05 sport with some 245/75/16 mtr's on and at full turn the front rubs a bit on the sway bar. I was wondering how much backspacing i would need to stop this. the help would be appreciated cause a lift and new rims are in the near future! I hope! lol the wife just wrecked her car today so i dont know. thanks!
dnm45227
Midwest
Man that stinks. Hope no one was hurt in the crash. Maybe she'll get a kj now?
kolesy
Goldsboro, NC
Yeah she wass alright and everything. her car was pretty beat up but still fixable per All-state. so she is still keepin that but dont worry im sure we can talk her into a KJ eventually!
cpliberty04
Richmond, VA
I would like to make sure that I understand the Offset Conversion Chart correctly.
If my stock wheel is 16x7 with 5.5 offset = 38
The chart shows 16x8 with a 4.5 offset = 0
Does this mean that the 8" rim with 4.5 offset will be no different than my 7" rim with a 5.5 offset? The new wheel will be in the same position as my factory wheel, just an inch wider correct?
Thanks!
cpliberty04
Richmond, VA
Never mind. Guess this was a stupid question. I've decided to go with 16" Renegade wheels, so I'm just replacing one stock wheel for another. No calculations necessary.
MeatBag
I have two questions please:
1. What's the axle hub diameter for 2003 Liberty?
2. Is the stock offset +41 for all four 16x7 wheels, or are the rear wheels different?
Thanks!
LibertyOrDeath
I have this same issue with the stock wheels. Will rims with 4.5 or 6.5 in of BS fix it. I am looking at the silver soft 8s and am guessing the 4.5 is the answer. I tried searching first but I am using my phone so its diffucult to use the search function.
bigBlue
Trinity/Tampa, FL
I have the 17" alloy/chrome (whatever) rims. What are the stats on this rim. Cant find anyone who knows, not even the local Jeep Dealership (haha).
jas32
SE Michigan
Response is about 4 months late but the specs, from what I can gather, are as follows:
17" (diameter) x 7.5" (wide)
Bolt pattern: 5 X 114.3mm (4.5")
Hub Center Bore: 71.5mm
Not sure about the offset but most likely it's the same as the 16" wheel at +41mm.
Jo6pak
Left coast of WI
Wheel Spacers and Back Spacing
This is most likely an obvious answer to a stupid question, but here goes.
How do wheel spacers affect backspacing?
Am I right to think that a 1.25" wheel spacer effectively increases the backspacing of the wheel the same amount.
Example. If I use a wheel 7" wide wheel with 4" of backspacing (offset= 0)and add a 1.25" wheel spacer, would backspacing then equal 5.25" (offset= 32.)
You went backwards...................
4" of BS then add a 1.25" spacer you will be effectivily at 2.75" of BS,pushing the wheel out farther.
Jo6pak
Left coast of WI
....:favorites68:
Just when I thought I had this stuff all figured out
now I'm really confused.
:emotions122:
If the "backside of the wheel mounting pad" is the center that mounts against the hub.
The "oustide of the rim flange" is the curb side of the wheel.
Doesn't the wheel spacer (between the hub and wheel) increase the distance?
.........Maybe I'm just overthinking this....
