power inverter
J-Thompson
just south of doucheville
well not in the KJ but in my work truck I have a 1000W/2000W trip-lite
it is mounted under the rear seat of an F250
the distance required me to use 1-0 awg wire ,cut the ends off of some jumper cables
I can run any thing I want ,as long as the engine is on
I have a 500 watt mounted on the angled part between the outlet and the window on the passenger side. Been there for over 4 years and not one problem. Its close enough that if I need to run a laptop up front the cords will reach and handy to have at the rear gate. Worked great for the Christmas lights as well!:D
twack
rochester mn
wow guess im the first pic in here. Now theres 2 ways to power these. 1 is hardwire to battery with either wireing/alligator clips or you can use a cigarette lighter. If you use a cigarette lighter it will not be as powerfull and will not run near as much. But for some reason the rear cigarette lighter in the kj holds much more power. I have no troubel using the rear one. but because i have subs i am probably going to wire into that power wire so i get full power. 400 watts for me camping is just fine.
DAGtunes
Big Bear Lake, CA
Instead of permanently installing, I have a portable 4 in one unit that connects to the rear 12v. accessory plug for charging.
It is a 400watt inverter,jumper cables and tire air compressor.http://www.canadiantire.ca/AST/browse/4/Auto/SolarPortablePower/PowerPacks/PRD~0111810P/Motomaster%2BEliminator%2B600A%2BPowerBox.jsp
I have something similar to this - a standalone/portable. Got it at Costco, it's called the "Powerdome" - 500W inverter. Has it's own sealed battery, which I charge up at home before a trip. Has onboard Air Compressor, Jumper Cables, and a worklight.
Weighs about 10-15 lbs, and is about the size of your average car battery - with a nice sturdy handle.
Inc
Free
I don't know which direction I am going to take. :confused:
I have one of those portable charger/air compressor/jumper but I don't like lugging it around.
Inc
Free
what do you want to power?
that will play a huge roll in what you do
I had a 3 gallon air compressor I was going to mount in the rear of the jeep, and it was a 110v plug in. I've decided not to mount it but I still want an inverter, just not sure how big and powerful I need. I've never really had a large need for one, but one would be nice to have.
J-Thompson
those thing pull lots of current
look at it like this W = V * A
so if a device is rated for 1 amp at 120V then that is 120W
now A = V / W
so 1 amp at 120V = 120W
120W at 12V = 10 amps
Those small compressors pull over 5 amps at 120V
so over 600W and take 150% to start them
so for a 5 amp compressor you will need at least a 600/900 inverter
but 5 amps at 120V is 50 amps at 12V
in other words you are going to be running some HUGE cables to the back of the Jeep
Inc
Free
now A = V / W
Which is why I am rethinking the whole thing. Not sure I want to go that route and get that far into it.
AMPlibby06
Rochester NY/Burlington, VT
close enough for passenger to use (i find that passengers use it most) but high up enough to avoid snow/water. thought i'd join twack since he seemed lonely having the only picture :p
beartard
Winter Haven, Florida, USA
now A = V / W
If watts = volts times amps (P=IE)
then
amps = watts over volts (I=P/E)
Your math was right, but the formula was backwards ;)
BjBnet
Ottawa, Ontario, Canada
What gauge wire did you use? I just installed my 700w in that same spot...thanks for the idea. Now I just need to connect it
LibertyFever
New Brunswick, Canada
I have a 400W inverter beneath the passenger's side seat wired to the battery with 14 gauge wire. Not positive what value of fuse that I used. It's for my laptop.
Also I have a 1,500W inverter that I jumper directly to the battery with the engine running for the heavier appliances (coffee maker).
