Transfer Case Cable Bushing?
libertybob
Lilburn
The transfer case shift cable way too much clearance between the cable end and the input pin for the shift arm. It appears there was a bushing in the cable end at one time and it as well as what was holding the cable end on the pin is missing. Does anyone have a picture of the transfer case cable end? I was thinking of making a bushing out of 5/16" fuel line to tighten up the clearance and using an e clip to hold it in position. Anyone else have this problem? Thanks
Leeann
Maryland
Mine looks like this, before I reattached it:
jeeptorino68
Oregon
google a bit more, same problem on wranglers.
i got an aluminum spacer/sleeve from the hardware store to replace the missing plastic bushing, then i held it on with a hitch pin or cotter pin?
Leeann
Maryland
Someone on here or on LOST figured out that a ¼" steel axle nut thingy from ACE Hardware snapped on and held everything in place. I was going to do that but my nylon clip was intact.
Nylon deserves to be on my fishing rod, not used as a clip or bushing. :fish_h4h:
blackhawk
Venezuela
Well, more than a year ago, I put this metal "ring" around the cable end. Hope it helps you.
