Throttle Positiion Sensor Replaced (TPS)
I have been chasing problems without any MIL, engine lights or codes.
Symptoms include starting cold and almost stalls & then gets going normal within 2 seconds.
Surging idle with throttle advanced to aprox 1700 rpm see video:
[/URL]
Good Read about TPS Link: Symptoms of a Bad Throttle Position Sensor
I wanted to find a new Hall effect sensor!
Conventional original equipment and replacement throttle position sensors have metal contact fingers that sweep across a printed resistor board to indicate throttle position.
Repetitive motion and vehicle vibration can cause these fingers to wear holes in the board, causing dead spots that result in engine hesitation / surging & and other drivability issues.
I knew of a company called Airtex and called them to see if they actually did have a new series of hall effect TPS sensor for the KJ!
Link: http://www.airtexve.com/sft696/airtex_tps.pdf
Unfortunately their current production of TPS sensors are not hall affect and made only to OEM specs. Will they ever make one, who knows at this moment.
If anyone knows of a hall effect TPS sensor for the KJ speak up!
So I had no choice as the Jeep was running like an ole bucket, but to buy an OEM Mopar TPS.
54709[/ATTACH]"]
The old sensor was chewed up a bit..
54711[/ATTACH]"]
and live data graph scan may have shown the exact interior fault position.
Unfortunately the shop that has the SnapOn Ultra was closed. The 5V VOM sweep proved to be inconclusive of a dead spot.
Anyways, I hope this information may prove to be helpful!
My Jeep no longer has the surging rpm, and it started right up without wanting to stall today after the New TPS was installed.
You do turn the TPS slightly clockwise to align the interior throttle tab, holding it inwards, then swing it back counter clockwise 1/4 inch aprox, to now tighten bolts back in.
Most is good under the hood now! :party52:
Good stuff. That was exactly what happened to mine a few years back and the TPS change fixed it. I eventually got a code. Was either a p0120, p0122, p0123 or something like that. Can't remember the exact number.
It was way below freezing this AM, Jeep sat 10 hours, and it fired up without any hesitation again!
This is looking real good!
I wish mine would have given any code, this was a tasking experience without!
^ Thanks Fellows...
One more bonus tonight, a cold start @ idle would normally produces some pop-i-ty exhaust notes at tailpipe.
Exhaust is now quiet, it's like the Jeep is saying "Thanks"...:icon_lol:
I bet I will get better mileage now too. Will have to test that theory soon.
