Logan Savage
2005 Liberty 3.7 . With field wires plugged into alternator I get a code for # 4 injector & engine won't rev above 2200 rpm's .
Unplug field wires , clear codes & engine runs fine . Have tried two alternators & batteries & new PCM .
I read to test the alternator to see if it's charging to unplug the field wires & jumper the field terminals on the alternator , one to battery terminal on alternator & other wire to alternator case . When I tried this the injector code & no rev problem came back .
Seems like I have an overcharge problem instead of an undercharge problem or it's something else entirely . I am considering adding an external regulator kit . Any ideas on these problems ?
