NeverEndingKJissues
hello all,
a few months ago my 2005 jeep liberty started to have a weird issue while driving. it would basically lose power for a half second while driving uphill, but after letting off the gas it would get power back and be fine. the problem escalated to actually stalling while going uphill at around 50-60 mph. the car would fire back up just fine, so had the codes pulled and it came back with p3044, intermittent camshaft sensor? I went ahead and replaced the camshaft sensor thinking it would fix the problem, but the next day the car stalled on my drive to work. I went and pulled the code again and got the same p3044 code. I'm assuming it wasn't a bad part, but I really don't know. I'm at a loss as to what to do, I don't have money to have the problem diagnosed by the dealership, let alone the money to have it fixed. I'm just wondering if anyone has any suggestions. I have very limited knowledge as far as cars go, I did notice on the TJ forum that excessive clearance could be an issue. But the sensor is only held in by 1 bolt, which I cinched down as best I could. Is the clearance referring to something else? Could it be the wiring harness connected to the censor? or the wiring itself?
Any suggestions are appreciated.
