This doesn't look right.
So who had them loose ( I assume the alignment shop) and if so why didn't they tighten them?
Man bet it handles really funky as well plus tearing up those tires
wheeee32
Not the mountains.
That's what I thought. The lower ball joints are getting done tomorrow so I'll make sure and tighten those back to where they should be. Yeah going over bumps today made me feel weird. I just want it all solid so I can go flex it a bit to break it in.
TwoBobsKJ
Northern Ohio
Did you have an alignment done and that's where the cam bolts were tightened down to?
After I got my JBA UCA's the bolts found new homes and if weren't for my obsessive painting issues there would be rust around the bolts. But I have to say my alignment settings are quite a bit different than they were stock - or even after I initially lifted my KJ. Rides a ton better after getting the new A-arms but the alignment is pushed to the max.
I'm just going by the looks but it seems the first one has moved back and forth and not by the alignment tech
Armysniper
Space Costs FL
Wheeee can you post a pic of the liberty lifted. I'm here waiting to look at the finish product.......
wheeee32
Not the mountains.
He did in his other thread a week ago
Sent from my iPhone using the power of children's laughter
Yep. I'll post more pics there this weekend. Figured out the noise source I was getting over bumps. Upper a arms are hitting the frame. Gonna trim below them a bit so they clear.
So you have the Franky PLUS a clevis lift :jawdrop:
how may miles now on it
Plus UCAs will self clearance if you let them go
Luke
Interloper
Bancroft, Canada
^^^ what Mudd said
... how the hell did you ever get your clevis back in? You must be eatin' your Wheaties :happy175:
Yikes ... that CV boot in pic #2 is going to last about 12 miles ;)
wheeee32
Not the mountains.
Yeah I put the clevis lift on figuring that once it settled I'd want to do it anyways. I don't have a lot of miles on it. I only drive 10 miles a day during the week. Luke: Yeah the driver's side was a bear getting it on. My body was sore all over the following day. I have a huge smile on my face when I pull up to the Wrangler's with the showy wheels and big tires but no lift.:laughing1:
The reason for your noise now that I know you did a clevis is the fact you're too high. Frankys start out high and need several thousand miles to fully break in. You do a clevis only after it broken in and have most of the time 30,000 on or so. You don't do a clevis because someday you'll need it with a Frankenlift. Remove the clevis and a good bit of your noise will go away , or put up with noise and the other issues of running too much lift
When I did my mixed up last lift using Frankenlift parts / 790 springs etc at 50,000 miles it still sat the same height as installed. You have to be over 4 inches of lift which is too much.
wheeee32
Not the mountains.
Well I guess I learned a lessson the hard way.:emotions133: I'm gonna go smack my head in to a wall now.
