Roof rail removal
nullptr
Port Orange, FL
Ok, probably a stupid question...
Anyone here removed the roof rails from their KJ? Eyeballing mine, I don't think I'll clear the garage door if I put a mild lift on. They aren't very useful, either, and I'm not sure I like how they look.
It looks like it's a simple unbolt and removal, but that leaves you with a pair of holes in the roof trim.
If anyone has done this, can you confirm that the following parts will fill it in?
  • #57010239AD - Delete Roof Rack. MOLDING. Roof. Left
  • #57010238AD - Delete Roof Rack. MOLDING. Roof. Right
How are those installed, anyway? Just body adhesive, or is their a clip?
How high is your garage door, if regular 7 foot or so no problem, I can ( well could) go in with 1/2 inch to spare with over 4 inches of lift/ 32s and RL roof basket
nullptr
Port Orange, FL
I'll have to check it when I get home. Actually, I need to get the door replaced, so maybe I'll wait and check it once I do that.
tlrtucker
Denver
Removal isn't difficult at all. On both ends, just pry off the plastic cover to expose the bolts attaching the rails to the roof.
necro thread!
What are people doing to cover the openings if they do a full on rail delete?
M38 Bob
Arkansas
Just my opinion, but a rubber O ring around the original bolt screwed back in place with moderate torque to keep it from breaking would seal it up nicely. Or, a dab of silicone gasket sealer?
