Pin Numbers 2004-2007
spr0k3t
Missouri
Pin number? If it's a transponder key, you first have to have two working transponder keys. If it's for programming a keyfob/remote, you can watch this video here: https://www.youtube.com/watch?v=ZXjbyER_Ye0
For the transponder key, there is no pin you will be able to find as it's programmed into the computer. You can program the key using this information: 2005 Jeep Liberty Chip Key Transponder Programming Instructions
Keep in mind, programming a new key will still require two existing pre-programmed keys for this method to work. If you don't have two keys, you will have to have the stealership program the computer to the new/replacement key.
