smallcrimes
So, my 2005 Liberty (3.7) is currently throwing a P2311 DTC my way, and it's symptoms are rough idle and bucking in every gear when the engine speed hits right around 2k RPMs. As you can imagine, this makes for a terrible ride and lots of pissed off people who happen to land behind me at a light when it's time for take off.
Anyway, I typed out a whole thing about what I've done so far in testing and I think I've pretty well whittled down what the issue is - but if you have the time, and actually read what I've written/done AND you have some input or experience close to this, your input would be greatly appreciated. Especially if it can save me from doing something rash....
**Rough idle and driving through all gears, MIL on with DTC P2311 of concern, vehicle ‘bucking’ in every gear with engine RPMs @ or around 2k; cursory knowledge indication of #4 coil malfunction – situation preceded by intermittent P0300 DTCs**
• Testing performed with all coils/fuel injectors/cylinders in mind:
All coils and fuel injectors metered for impedance within spec (all coils primary resistance within . 6Ω - .9Ω & secondary resistances between 7.25 kΩ-8.84 kΩ. Fuel injectors all tested right around 12-13Ω)
All fuses and relays in related circuits tested/verified
All connections inspected and verified as secure
Grounding straps tested with no voltage drops
All plugs recently replaced and gapped to vehicle’s EPA information (.040); at onset of recent symptoms, all plugs were pulled and inspected – all had virtually no real wear, except on #4, which had heavy carbon deposits.
Fuel pump relay removed and all coils individually tested for spark. All had good, healthy spark, with the exception being #4
• Testing performed to specific coils:
Coil #1
Metered for continuity between ASD relay out on 87, and supply at coil (Rd/Org), as well as continuity between PCM and the signal wire (YL/DB – pin 1 at coil connector, C2/pin 10 at PCM).
Supply tests @ 14.3vDC with engine running.
Signal wire tests @ 2.36vAC/.707vAC min/max.
Coil #2
Metered for continuity between ASD relay out on 87, and supply at coil (Rd/Org), as well as continuity between PCM and the signal wire (DB/YL – pin 1 at coil connector, C2/pin 9 at PCM).
Signal wire tests @ 2.43vAC/.716vAC min/max.
Coil #3
Metered for continuity between ASD relay out on 87, and supply at coil (Rd/Org), as well as continuity between PCM and the signal wire (DB – pin 1 at coil connector, C2/pin 7 at PCM).
Signal wire tests @ 2.47vAC/.727vAC min/max.
Coil #4
Metered for continuity between ASD relay out on 87, and supply at coil (Rd/Org), as well as continuity between PCM and the signal wire (DB – pin 1 at coil connector, C2/pin 3 at PCM).
Signal wire tests @ 152.9mVAC/128.7mVAC min/max
Coil #5
Metered for continuity between ASD relay out on 87, and supply at coil (Rd/Org), as well as continuity between PCM and the signal wire (DB/YL – pin 1 at coil connector, C2/pin 2 at PCM).
Signal wire tests @ 2.39vAC/.707vAC min/max
Coil #6
Metered for continuity between ASD relay out on 87, and supply at coil (Rd/Org), as well as continuity between PCM and the signal wire (DB/OR – pin 1 at coil connector, C2/pin 1 at PCM).
Supply wire tests @ 14.3vDC with engine running.
Signal wire tests @ 2.41vAC/.712vAC min/max.
With all this information in mind, I determined that the problem lies with the fact that the coil on #4 is just not getting the signal it needs for spark. Just to rule it out, and even though it tested fine for continuity, I did run a new wire from the PCM to the connector at #4. Unfortunately that amounted to nothing, and I have to believe that there must be a problem with the PCM itself. Without knowledge of the interior layout of the PCM, or whether or not there may be isolated corrosion, etc. on only one part of the internal board (pins and receiving cavs on connector appear fine)- the question seems to be, “Why would the PCM send a weak signal on only one pin and have no indication of failure for the others?” I’m left wondering what conditions would cause this.
Now, I've been told by a friend who runs a shop that I maaaaay have to just get the PCM reflashed. The cheapest I can get that done for around here is at $175 pricetag, which is just anklegrabbin' mode as far as I'm concerned. The only other option I've debated trying is one of those "hey, we'll send you a new/refurbished PCM flashed to your exact mileage and VIN" places, but that sounds shady AF and I couldn't afford to not drive my liberty for however long it takes to come in the mail (considering the ODO).
Anyway, if anyone's made it though this I applaud you. If you've had this same problem. I'm sorry. If you have an answer that I may find more on terms with my cheapskate outlook on life....I might have to send you a bottle of something.
Thanks, whatever way this finds you.
-D
Coil #1
Coil #2
Coil #3
Coil #4
Coil #5
Coil #6
-D
