Andynator
Hi Everyone,
Here is a general question for everyone who has the Mopar roof cross-bars:
I installed them. They look fine - the teardrop cross-section ones with the rubber strip on top. I was a little worried about the small hex screws inside that tighten the clamp up against the roof rails. But I piled my gear on top, right on the roof and tightened everything down with ratchet straps and everything stayed put on a 1200-mile road trip, even with some nasty cross-winds. Cool.
Here is my question. I am going to install a roof basket / safari basket (probably Surco because I can get it oversized and not the std 39 x 40). Are the small hex screws holding the Mopar cross bars going to be strong enough? Because I have this mental picture of the air flow going UNDER the loaded roof basket and pulling it and the cross bars right up off the roof rails. Not that I will be driving at mega-high speeds or anything. Just a little nervous.
I had an extension ladder ratched down to the cross bars last fall and a STRONG cross-wind blew it across the top and down the driver's side where it was still hanging on to the roof rails, but I had to pull off and climb out the passenger side because the ladder was hanging and blocking the driver's door. Did some nasty scars on the paint too. Probably was not ratched tight enough but making me a little gunshy about carrying cargo on the roof.
Comments appreciated.
Thanks,
Andy
'02 LTD
Thanks,
Andy
'02 LTD
