Help on removing oil from block
Tanji
Austin Texas
Hey guys! I am trying to replace the oil pan gasket and oil pan but the pan is stuck to the block. Is there any way I can get it out without damaging the block?
Thanks!
Tanji
Austin Texas
Okay. So after a few hammering and peeled off skin, I managed to loosen the gasket away from the engine block but the gasket is now stuck to the pan T-T . Any advice?
turblediesel
memberable
Alaska
I usually use a putty-knife or single edged razor blade. What's left comes off pretty easily with some solvent and light wire brushing.
mrlavalamp
Sin City
Seconding the putty knife and solvent. The putty knife I use was the cheapest metal bladed putty knife I could find. the blade is very thin and flexible, which actually makes it cut like a razor blade and gives it some flexibility.
When I did mine, the PO (or their mechanic) put it on with orange RTV. The great thing about RTV is that if you use a little ammonia floor cleaner, and a little elbow grease with your scraper or a wire brush, it comes off very easily.
turblediesel
memberable
Alaska
I think they're designed to go together fast at the factory but changing oil pan gaskets just comes with all the miserys built in regardless of what you're working on.
