having diff fluids changed got???s
RenegadeJay
outside Chicago
I am having both front and rear diff fluid changed. I read that you need an addtive for the rear if you have the Trac-Lok rear axle. I don't know if I have it. How do I tell? 2006 Renegade, 3.7l, Command Trac, ESP.
should be a tag on the rear axle right side if not your build sheet would tell you as well
The Chrysler limited slip additive is required for the Trac-Lok.
AS Tom mentioned....TAG or "The build sheet" is important and all owners should have one and know if you have a Trac-Lok.
A copy can be obtained by calling Chrysler or dropping by the dealer with you VIN#.
Here is a photo of the 4 oz bottle which has the part number on it. (0431...)
37038[/ATTACH]"]
Use GL5 it last longer than synthetics.
But still change out the rear diff fluid every 12,000 miles with Trac-Lok.
Otherwise expect to rebuild the clutche$ or install a Richmond Locker like TBJ.
Open and Trac-lok look similar but...clutch pack is kinda hidden in-between the gearsets, so to the inexperienced flunky who may not work on Jeeps then what?
One thing is certain...you should know if you have a trac-lok before you go to any shop to ensure you got the right stuff, as running a posi without the friction modifier is certain death to your diff.
37040[/ATTACH]"]
If you are not sure just add the friction modifier, it won't hurt an open diff.
RenegadeJay
outside Chicago
thanks, I'm not at home so I couldn't check my build sheet. Maybe I'll just buy it to be safe.
RenegadeJay
outside Chicago
thanks, I'm not at home so I couldn't check my build sheet. Maybe I'll just but it to be safe. Unless it cost more than $10. Then I'll check what I have.
In US should be under or around with tax $10....
Why:favorites68:around just add it.
RenegadeJay
outside Chicago
Here is what my build sheet says:
All 4-Speed Automatic Transmissions
4-Spd. Automatic VLP 42RLE Trans
Lock-Up Torque Converter
Command-Trac Part Time 4WD System
Dana 30/186MM Front Axle
3.73 Axle Ratio
Corporate 8.25 Rear Axle
I bought a bottle of Napa's friction modifier anyway.
shawn-o
Winnipeg, MB
I was under the understanding if you used Royal Purple Max-gear, It has the friction modifyer already added.
From their website::
All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary.
Troy look at his build sheet..some 06 were built in late 05 etc...
I thought ESP/traction came on 07's and above..
Looks like he has an open diff...no mention of Trac-Lok.
And Shawn..ya many GL5 already have the limited slip friction modifier added, and yes that will work, but many still prefer to use the Chrysler Friction Modifier.
Any model year '06 KJ,regardless of when it was built(in '05 or '06) has ESP and traction control and no option for trashloc.
Thanks Troy...
Will try to embed only up to 05 then as avail. w/ trash lok.
1 year past mine easier to remember!
RenegadeJay
outside Chicago
My 06 was built 5/06, which really doesn't matter with the info TJKJ provided. Seeing how I don't have the trac-loc but I purchased the friction modifier should I have it added or just return it? I mean if I don't need it I hate to tell the guy working on my car to add if it is unnecessary. But if it is still a good idea to use it then I will. The mechanic who works on my cars does it as "side work", he works for a diesel truck repair shop so I dunno how knowledgeable he is on Chrysler products. Not to mention I don't know what types of fluids they have at the shop that are useable in the KJ. The owners manual specs 1 type of fluid for the front diff, and another type for the rear but the sticky thread "required fluid types" says ........
"FRONT DIFFERENTIAL: 80W-90, 75W-90, 75W-140
(change every 12,000-15,000 miles)
(2.6 pints)
REAR DIFFERENTIAL: 80W-90, 75W-90, 75W-140
(4.3 pints)"
What does that mean? You can use a range? Can you use the same fluid front and rear?
Since you do not have trac-lok , You will NOT have to add any friction modifier.
Just regular GL5 gear Lube and you are fine.
Most use 75W-90 if you are not towing anything.
However if you are towing the recommended GL5 will now be 75W-140
Hope that clarify's things .....
diyman
Venezuela
(2.6 pints)
(4.3 pints)"
They just want YOU to loose sleep ....:D
Unless You treat Your KJ so bad ( someone would say ... properly) no need for 75W-140, it's thick and would add additional 'drag', particularly in the cold season. Just IMHO.
PS : I use 80W/90,GL-5 dino, but I do get it cheap...
If you tow anything or oddroad thicker gear oil is better.
Personnaly I run 85w-140 dino GL5,I like my diffs and could care less about mpg's.
I have ran the 75-140 for the last 130,000 miles with no ill effects, when the gears were swapped recently they still looked new
