Couple Questions Please
sleepyjim
Bullhead City, Az.
First I am getting new Upper control arms from JBA, should I be replacing anything else?
For an 04 gas 3.7 is the timing chain lifetime? I read someplace that they dont need replaced, is this true? I need a water pump and was thinking of doing the timing chain and other stuff at same time.... I am still under 100k miles yet.
Hood louvers or some kinda scoop or?? to get more air under the hood/release more heat? I live in AZ and my lil libby gets mighty hot.
Since my lift (Thanks Tom) she performs so darn great! what is the next performance step.things I should be saving for?
Thanks!!
Jim
Tog
AU
dunno bout lifetime on timing chains but I had to do mine 12 mnths ago they stretch and get a bad rattle
2004 3.7 limited
Billwill
White River, South Africa
Gets pretty hot here in SA as well!
My 2002 Export CRD has mechanical fan but not a separate electric fan as later model CRDs do and on a slow crawl on a hot humid day through a National Park...max 50 kmh on asphalt roads and 40 kmh on dirt road...I could feel the heat buildup under the hood.
I saw a quick-fix on one of the KJ sites which helped a bit.
Lift up the hood and on the firewall in front of the wipers is a rubber strip sealing the rear of the hood when closed to the firewall. Simply remove this rubber strip and heat has some more access to escape from the engine bay!
I ideally need to find an electric fan to add to the existing mechanical fan!
Thanks!!
Jim
Pontiac GTP hood lovers do a great job, have ran them on XJs, and my 04 , still looking for a set for my 03
Lots of people way over what you have and no issues with the timing chain
2004 3.7 limited
I don't know anything about timing chains stretching or the physical dimension of the chains increasing. Seems unlikely without them breaking but I do know the timing chain hydraulic tensioners can wear/weaken and cause the rattle. Had that on my 02. Just changed the tensioners and rattle gone.
Tog
AU
Thanks!!
Jim
my mechanic showed me the old chains vs new the old were definitely longer just enough that the tensioner could no longer take up slack
2004 3.7 limited
2004 3.7 limited
Interesting. Lucky you didn't jump timing. Hopefully he did the tensioners too, cuz they definitely weaken with age and that couldn't have been good for them. How many miles were on them?
Tog
AU
did the full kit,tensioners, guides , chains etc. think it was about 232000 km when they went.
2004 3.7 limited
