Kevin.G
- Joined
- Nov 18, 2023
- Messages
- 12
- Reaction score
- 23
Has anyone heard of this? I know the previous "mechanic" that worked on my KJ, removed the arm to replace bushes and ball joint. Now that I am replacing these items again, I have found the following:
1. Sub standard aftermarket bushes
2. The ball joint was never replaced, supposedly because they could not get the ball joint out of the arm. I suspect in the process of of attempting the removal, they possibly Bent the one side of the arm.
The bend is hardly noticeable, but it CAN be seen with the naked eye once picked up. Now apart from the severely worn bushes, there has been no other untoward problems other than a somewhat "loose" backend over uneven surfaces normally associated with bad bushes. BUT, I have also picked up a slight diff whine when under load, but silent with my foot off the gas. My question is/are:
1. Would the diff Wine have anything to do with the Bent arm?
2. Noting that there is no tracking issue or uneven rear tire wear, would it be necessary to change the arm. Remember, here in Africa these are difficult to obtain and expensive to import.
Regards, Kevin.
Regards, Kevin.
