Are JBA UCA's as necessary as Marlin Gehman makes them sound?
dlicata
KCMO
My KJ has a 3" spacer lift currently, and I'm in the process of changing to a proper 3.25" Bilstein/OME lift. My question is, with 171,000 miles on the car, am I at any risk of UCA failure and in need of either new OEM UCA's or JBA UCA's?
Yes and would always highly recommend JBA UCA's with any lifted KJ/KK.
A must have,almost bordering on required.
jeeptorino68
Oregon
Especially at that lift height you need them. Its not failure, but having all,the geometry proper. Or close too. Without lengthening them and changing the ball joint angle. You will chew through ball joints on the factory length arms. And they will hit the coils at full drop
rjkj2005
US
Same lift in both pictures. 3.75 inches of lift. These were taken with wheels on the ground. 3 inches is max with factory UCAs.
Sent from my SM-G965U using Tapatalk
Jo6pak
Left coast of WI
I had the same question, dlicata.
After blowing through my second set of OEM ball joints, I went with JBA and never looked back. I think the JBA control arms are actually cheaper than OEM replacements too.
Damotee
Cape York, Australia
I was running the stock UCA's with my lifted Jeep. The stock ones perished quite quickly with the ball joint boot tearing and the arm itself rubbing on the coil spring. The JBA arms are quite pricey, but worth it if lifted.
YES ON THE JBA's
RenKJ
Canada
With the lifted JBA's is the brake lines an issue? Am ordering JBA's myself today.....
Jim
Front lines will be fine, you need to drop driver side rear brake bracket if you lift
Sent from my SM-N910W8 using Tapatalk
Myke
USA
Yes to the jba uca. Don't be ghetto.
RenKJ
Canada
It may seem like you can get away without brake braked drop but if you flex out the rear fully frequently you're putting the rubber line under extreme stress when left side droops fully
Fully flexed out several times and never an issue
Of course did a lot of measuring/ adjusting/ adding little extras to get the most amount of flex, but not over exceeding the amount where it would stretch out the brake line
Charlesthe2nd
Portland, ME
You need it also on '02-'05's.
Ripped mine apart when I first lifted the KJ.
I have the JBA SS brake line kit sitting in the basement, waiting for my rear shoes to reach the end of their life, then doing a brake job. The rear brake line gets pretty taught when I'm working on the rear, and it's fully drooped out. Sketched me out first time I saw it.
What was it like losing your brakes on the trail? What comes to mind for me is the Bronco careening down Lions Back in Moab, a true nightmare.
Aceofspades
Buffalo
I would like to confirm this. My 03 has no issues “so far” but I’m lifting the 03 next week. Is the brake line going to be an issue or is that for the later years like stated before ?
