2004 Liberty No parking lights, or dash lights
robert_grose
fuses ok, bulbs ok, connectiions ok, no power at the fuse box, switch replaced.. I have no wiring diagram of the body control module. Could the bcm be my problen???
turblediesel
memberable
Alaska
A weak old battery can make odd things happen. Try the standard reset of disconnecting the battery and clamping the battery clamps together for 45(?) minutes.
Mine wouldn't start when my battery got old but it did open the rear door glass.
robert_grose
The battery is new. Al
I appreciate your response. But I tried what you suggested. To no avail. Is there anything I may have misused?
gayle.woods
Are you saying you have "no power" at the power distribution center in the engine bay just in front of the battery?
robert_grose
Negative.. No power at fuse box by driver side fuse box. Numer 7 and 9 have no power.. Both are 10 amp fuses
gayle.woods
See if the attached pdf will help you out.
  • All Wiring Diagrams for Jeep Liberty Sport 2003.pdf
gayle.woods
Check you grounds as well. I would think if you are not blowing fuses that you are not shorted to ground in the circuit so it must be opened circuited somewhere. My instrument lights stop dimming and I could not turn on the dome lights. Found out it was a broken wire in the left stalk (multi-function switch) that was not visible until I removed the unit from the steering column and turned it upside down.
