robert_grose
- Joined
- Feb 2, 2022
- Messages
- 6
- Reaction score
- 2
fuses ok, bulbs ok, connectiions ok, no power at the fuse box, switch replaced.. I have no wiring diagram of the body control module. Could the bcm be my problen???
The battery is new. AlA weak old battery can make odd things happen. Try the standard reset of disconnecting the battery and clamping the battery clamps together for 45(?) minutes.
Mine wouldn't start when my battery got old but it did open the rear door glass.
I appreciate your response. But I tried what you suggested. To no avail. Is there anything I may have misused?A weak old battery can make odd things happen. Try the standard reset of disconnecting the battery and clamping the battery clamps together for 45(?) minutes.
Are you saying you have "no power" at the power distribution center in the engine bay just in front of the battery?fuses ok, bulbs ok, connectiions ok, no power at the fuse box, switch replaced.. I have no wiring diagram of the body control module. Could the bcm be my problen???
Negative.. No power at fuse box by driver side fuse box. Numer 7 and 9 have no power.. Both are 10 amp fusesAre you saying you have "no power" at the power distribution center in the engine bay just in front of the battery?You must be registered for see images attach
Also I have replaced the telay that is behind the fuse box under the dash..Negative.. No power at fuse box by driver side fuse box. Numer 7 and 9 have no power.. Both are 10 amp fuses
