07 Sport Radiator (CarQuest?)
Duster
NC
It just keeps coming. Now the radiator is leaking somewhere.
I already picked up a radiator from Advanced. It's a Car Quest one but I saw China on it.... So I was like I dunno, might should have had someone take me to the Jeep dealer. But bet they wouldn't have one on hand anyways. So I stopped by my radiator guy and asked him about it.
He said it's not cracked by the upper driver side mount like others he has seen. I asked and he said almost everything is made in China anymore. Put it on, bring back the old one for a patch repair as it seems to be leaking in the middle.
Anyways, anyone replaced with a CarQuest radiator?
Trying to decide if I should even put it in. My trouble is I really dont have time to fool around and wait on a repair patch or a Mopar radiator to come. I mean it is not leaking bad yet but its a steady drip and I fear that will pop into a gusher. Its driven daily and I'm loosing money when it is sitting still. But I hate to install $160 radiator and have it not last, etc...
meoget
MI
The general consensus around here, is that you should replace the radiator with genuine Mopar replacement parts.
I was in a situation where I didn't have time to wait, so I put a $90 Vision radiator in my 05, and it has been fine for 16 months.
That's just my experience, but it seems that aftermarket radiators are a problem. If I could have had a Mopar radiator when I needed it, I would have done so.
x2 on Mopar is the best
Although I've had a Spectrum one for 3 years, 50k miles and knock on wood it's been ok. The guy that installed it said that he's never had any issues with them.
In a pinch, I'd take a non leaker over a leaker.
CalcityRenegade
Calgary
Had a Spectra rad for under a year and it started leaking. Replaced with a Mopar rad and never had an issue.
One of my KJ friends bought NAPA ( Chinese brand) , 11 replacements in 2 years finally gave up got Mopar and no more issues
Duster
NC
Uggg.... sounds worse than the Ranger heater core situation I went through after the OEM one started leaking. I would have to put replace in the spring after I stopped using heat, and in the fall when I started using heat. Finally found a good one at NAPA not made in China. No problems since.
I do believe I will eat this one and install it to stay rolling. Then take my old one over to the radiator shop for repair since it's not cracked by the mount. Then I will have it to put back later.
GunnerSchenck
If you get the old one fixed, id swap them out right after.
A reason a lot of the cheaper ones end up leaking is in design flaws for the cooling tubes and fins..
Then you'd have the cheapy for a backup instead of a Mopar backup.....
renegade 04
Albany New York
The best would be to ditch the plastic tanks, when I get the money I will be buying an all aluminum radiator.
